It is currently Thu Aug 14, 2025 3:36 am
PostPosted: Tue Oct 13, 2015 7:18 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I've noticed this, I'm sure all of have. I just don't quite understand why it's such a great technique. For most of my wet sanding, I use mineral spirits. Does anyone have the info on this?
PostPosted: Tue Oct 13, 2015 7:49 pm
First name: Danny
Last Name: Vincent
My wet sanding starts at 1000G so I guess it's more like wet polishing. Yes, it does a great job.
First name: Danny
Last Name: Vincent
PostPosted: Tue Oct 13, 2015 7:50 pm
First name: Danny
Last Name: Vincent
Should I keep going? oops_sign
PostPosted: Tue Oct 13, 2015 7:55 pm
First name: D
Last Name: S
Hmm, mineral spirits.
I need to try that.
Water swells holes, and soap leaves a nasty white scum in the places you can't get to.
Thanks for the tip.
wah
Wah-wah-wah-wah
Wah
PostPosted: Tue Oct 13, 2015 8:50 pm
I believe the slurry has a lot to do with it, similar to creating a slurry with a nagura stone on a waterstone when we sharpen.
I'm not sure what the slurry actually does, which is at the heart of your question. I suspect it washes away the dust and debris and leaves the grit at it's most aggressive, but I'm just speculating.
Interestingly, when I sanded some fully cured Royal-Lac with basic 600 grit dry a few weeks ago, it was literally like sanding a block of chalk. I chalk my hands all the time when I work out, and the cured Royal-Lac behaved exactly the same. I've never had something level so easily.
PostPosted: Tue Oct 13, 2015 9:35 pm
Water sculpts the entire world.
It's the slurry and it helps flow out the build up too.
PostPosted: Tue Oct 13, 2015 9:37 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I don't know why exactly mineral spirits works so well. For the finishes I've used (nitro, em 6000, and enduro-var) I get the same kind of slick emulsion. Water on em 6000 creates an unexpected stickiness or suction. Hard to describe. Maybe mineral spirits stays "slippery".
I've had the same thought that it's the emulsion or slurry that adds to the polishing effect. It doesn't feel more aggressive to me, rather the opposite. It seems to remove pressure point effects. The paper is evenly drawn to the surface wherever my fingers are. Definitely some kind of physical process going on.
PostPosted: Tue Oct 13, 2015 9:39 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Btw, maybe it's similar to pebbles in a stream? Rolling rocks in a tumbler without liquid does not result in the same finish as with liquid.
PostPosted: Tue Oct 13, 2015 9:59 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
Agreed Mike, I use light mineral oil (lemon oil) on EM6000 and it works 100% better than water for the reasons you describe...
PostPosted: Tue Oct 13, 2015 10:25 pm
Last Name: Schreiner
City: Miami
State: FL
Zip/Postal Code: 33183
As Dan says, water swells holes. Wouldn't any liquid do that..including mineral spirits? Lately I have been dry sanding around holes to avoid the swelling problem but the paper loads up very quickly.
Michael
PostPosted: Tue Oct 13, 2015 11:23 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
What holes are you all talking about? If you have sealed the surface, there are no holes. I'm confused on this
PostPosted: Wed Oct 14, 2015 12:00 am
City: Miami
State: FL
Machine head holes and in the case of my harp guitars, super treble zither pin holes. I drill these holes prior to finishing for various reasons.
Michael
PostPosted: Wed Oct 14, 2015 6:41 am
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
Another benefit that hasn't been mentioned yet is that it prevents the paper from loading.
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Wed Oct 14, 2015 7:01 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Michael
I don't believe so. Wood will absorb water which causes it to swell or raise the grain. It won't absorb oil, at least not in the same sense like water.
I'm not a luthier.
PostPosted: Wed Oct 14, 2015 9:41 am
Wet sanding is good, but dry sanding works well too and has some other benefits (such as being able to see your progress as you work). But you have to use a good, non-loading abrasive to make this work correctly.
PostPosted: Wed Oct 14, 2015 10:40 am
I wet sand water-based finishes with mineral spirits. On nitro or Royal Lac I use water with just a drop of dish soap. Both work well. I used to dry sand but now for initial leveling I wet sand with 800 and after the final finish coats I level by wet sanding with 1000. This is just what I'm doing now, may change next month idunno The only thing that really matters is that you find a process, wet or dry, that works for you.
PostPosted: Sun Oct 18, 2015 12:34 pm
First name: Tim
Last Name: Allen
City: San Francisco
"Lubrication" is often given as the reason for using water or other liquid, but it never made any sense to me. The amount of friction with dry sanding doesn't seem to be a problem, and anyway the liquid doesn't seem to reduce it, at least when I sand. Keeping the paper from loading up has been the main benefit I noticed, but I can see that the slurry and the vacuum effect evening out the pressure are other benefits, I can see.
Tim Allen
"Never hurry, never rest."
PostPosted: Sun Oct 18, 2015 4:50 pm
First name: D
Last Name: S
Sorry, I was talking about solid body guitars.
I drill all holes prior to finishing to minimize cracks and marring.
I tried the mineral sprits yesterday, works like a charm!
wah
Wah-wah-wah-wah
Wah
PostPosted: Sun Oct 18, 2015 5:30 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Wet sanding also keeps the sanding dust down.
Alex
PostPosted: Mon Oct 19, 2015 8:59 am
Wet sanding with oil creates a slurry that cuts the wood into ultra fine particles and leaves a glass like surface. Some folks do this using pumice and shellac to pore fill prior to a french polish.
PostPosted: Mon Oct 19, 2015 1:12 pm
First name: David
Last Name: Malicky
Zip/Postal Code: 92111
I suspect it's a combo of the above -- it keeps the paper from loading so it can cut better, it presents a more uniform medium to the surface (spot-loaded paper creates problems), and the slurry is an active abrasive of smaller particles to even out the heavier scratches. And as Alex said, less dust!
If the surface material is hydrophilic, water will swell it.
David Malicky
PostPosted: Mon Oct 19, 2015 10:17 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I think Bob and David's explanation fits my experience. I've also noticed that you can experience more aggressive sanding with wet sanding. Probably due to the non-loaded aspect of the process.
PostPosted: Tue Oct 20, 2015 2:46 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Wet sanding a finish keeps the paper from loading. What little abrasive is lost from the paper is suspended in the lubricating liquid, so does not aid or detract from the paper's cutting action. Like a dry, pere-lubricated paper, a properly prepared piece of wet/dry will resist loading for as long as the lubricant is present. Renewing the lubricant frequently removes dead finish and other contaminates, so aids cutting action. The slurry is largely composed of lubricating liquid (water, mineral spirits) and particles of finish, so there is little or no abrasive action from the slurry itself.
My mentor keeps a couple of tubs of different wet/dry grits handy in water/dish detergent (the detergent kills surface tension and keeps the dead finish suspended), and any new paper is soaked for at least 24 hours before use. Some of the 3M and good Japanese papers have been in the tubs for 2-3 years and still cut like new. Paper is only tossed when the backing loses it's waterproof properties and degrades.
- Beth Brower
PostPosted: Wed Oct 21, 2015 3:06 pm
First name: lindsay
Last Name: mckay
City: edinburgh
State: midlothian
Zip/Postal Code: eh14 5jh
Country: u.k.
Wet sanding helps to remove, or keep mobile, particles abraded from the surface so that they themselves do not become abrasive.
The same effect can be achieved with air extraction through perforated abrasive papers as in the polishing of Corian
